1 - 8 of 8 Posts
it should be vented.now is this the vapor line to the charcoal canister or the fuel return from the fuel pump? if it is the fuel pump return you can cap it off at the tank. it was there to help prevent vapor lock.some had it some didnt. if its to the canister it should be hooked up to keep the tank vented and to prevent it from sucking the tank in
1 - 8 of 8 Posts
