Ok so I'm trying this gauge conversion thing. What I can not seem to find is what the pins on the back of the gauges are. I know three of them should be BAT, GND, SIG whats the last one, shared ground?
Fuel works, it's still factory
Battery voltage works, that one was obvious
coolant temp does not work, only spins around to the 5 o clock position
oil pressure does not work, only spins to the 5 o clock position
Now I've been looking for the actual cluster schematic but so far no joy. i ran out of daylight and my laptop died. so i gave up for the night. if someone has a picture of a circuit board or what each item is. would be great.
Once someone tells me what each one ..... you know what i'll go take a picture and post it with what i do know so far and maybe you all could fill in the blanks.
