1 - 3 of 3 Posts
New member looking for help. I'm going to remove the stock v6 in favor of a crate 350/320hp engine. I believe it has a 200C tranny. This will be a daily driver. What's the easiest tranny to put in it's place? Is there one that will be a direct swap as far as length is concerned. And finally, do I need to replace the stock coil springs to handle the new 350? Thanks in advance for any help. :)
you will need different motor mounts for the v8
remove the mounts from your k member. install new v8 mounts all the way forward.you will only be able to get 3 bolts in. because the bottom front holes on both sides will be hanging over, you will see it when you start. everthing will fit in place with the v8.x member will hook up and driveshaft also.
1 - 3 of 3 Posts
