1 - 16 of 16 Posts
1979 305- 350 auto.
Can
anybody tell me where this ground attaches. It comes from the firewall and appears not to have been hooked up for awhile.Found it while on the lift Saturday.
Thanks, Tom
On my 350, that ground is for the heater core where the hoses exit.
post #2
Recollection tells me that there is "V" shaped bracket that goes between the two hoses at the heater core, and the ground goes on the attaching screw...
The "v" bracket mentioned is inside the heater airbox, it keeps the heater core steady and vibration free. Don't know if the coolant flow causes an electrical charge or something, but the heaters seem to suffer from electrolysis for some reason, that ground strap discharges it.
You must remove the airbox cover to reach the bracket. You will probably need a 1/4 and/or a 9/32 socket or nutdriver.
Looks like a homemade ground wire and not a good one. I'd run a good ground wire to a valve cover bolt on both sides of the engine if I were you. You can't over ground.
Not a home made strap. X2 Heater core ground as stated above.
Discussion Starter #9
It’s a pretty good strap. Braided like the others up there. Looks to be connected to the firewall since built. There is another one to the right to the motor. I thought it was a hood ground for the light.
Tom
Hat Trick, 5spd and others are correct that that ground strap is an OEM item. It is necessary to ground and discharge any electrolysis charges that may build up within the heater core AND will require removal of the AC/Heater cover to reattach.
Go to minute 4 of the video above and you'll see what we're referring to. Also, I suggest looking at other applicable videos related to removal of the cover and where exactly to reconnect the ground strap.
Looks like the valve cover bolt ground, this wire will help to ground the motor. The last time I did a heater core the ground wire was smaller and clipped on to the heater core like someone stated to help with electrosis causing corrosion. Matty man
X2 😮
Looks like the valve cover bolt ground, this wire will help to ground the motor. The last time I did a heater core the ground wire was smaller and clipped on to the heater core like someone stated to help with electrolysis causing corrosion. Matty man
After looking at the picture the valve cover ground is to the right of the wire in question, I just thought the heater core ground wire was a clip and did not screw on. Heater core wire it is.
1 - 16 of 16 Posts
