1 - 9 of 9 Posts
Ive got a 70 Elco and need Headers on an installed zzz 350 crate motor installed in 1987. Brand? Short? Long? Y pipe? Thanks!
Ok that sounds good I like the long headers too. Did you have to move the engine at all to install them? Thanks
I have long tube tri-Y style headers on my '70.
They may have come off a Silverado/Suburban.
They hang so low that they are thoroughly dented.
Hey thanks I didn't think of that. Maybe I should try the shorty? What do you think? Thanks.
I didn't have to move the engine (do remove the spark plugs) but I did have to disconnect the steering shaft at the steering box and move it out the way. I think I also had to remove the clutch linkage. Use some kind of locking header bolts. Changing spark plugs will be difficult in the future. Had no ground clearance problems.
For my 1970 396 I installed Hedman 68616 headers, which are standard duty, HTC coated, shorty, and finished the system with a Magnaflow 2.5 in system. There was nothing that had to be moved or modified for header installation, but later I moved the brake line for the RF wheel after noticing that it passed within an inch of the header pipe. I don't drive the Elky much, but I am expecting to eventually have issues with the starter solenoid, which is also very close. I have the stock shield in place, but I don't see how that will protect the solenoid in the long run. Ground clearance of the headers would not have been any issue, but I dropped the whole chassis a couple of inches with a new suspension system.
Don't go with a big tube either, they can hang too low and be visible and get in the way on speed bumps
1 - 9 of 9 Posts
