my '68 elcam w/ A/C needs a new heater core. ive done a heater core before only it was worse ('89 Volvo 780 Bertone). i will have no problem completing this job once i get this answered: do i go in from the firewall (remove A/C assembly and stuff), go at it from under the dash of the pasenger side, or both. if you cant answer questions good please point out someone who can. thanks a bunch.
You got a bit lucky as the '68 W/AC is reached from under the hood. I recommend you go to the library or bookstore to get a Chilton manual as this is still a tricky job and Chilton has pictures. Regardless, be extra careful when taking the top cover off the module. You have to break the seal and if all retainers and screws are not properly removed you can break the module body and that means trouble. :)
Moderator
It is a easy job, just take your time. Remember all the plastic is old.
thanks. im starting the core removal today. well see how it goes. thanks again
install complete. it went okay. took me from 2 pm to 10 pm. the next day the water pump seal went out. oh well. thaks for the guidance and advice
Hey I need to know how to do this except on a 75 El Camino. Is it the same?:dontknow:
I know this is an old thread but I need to know if the Heater core removal is the same on a 75
