1 - 1 of 1 Posts
I’m having trouble where these wires go exactly. I have a pink any black wire that come from the ECM. I have a blue wire that goes down what I believe is the knocking sensorknocking sensor. And I have a brown wire that I do not know where to connect it to.
The brown wire was lead toward the front near the thermostat/coolant temperature sensor area. I noticed a long time ago That the brown wire was melted together due to engine heat with a black/white wire. So now my question is where does this brown wire go to or should I just re-connected to the black and white wire that it was mounted with.
My car currently is not running and won’t start but I’m trying to get all the wiring in place because I’m going to replace the engine. I believe all the Rest of thewiring is in tact.
131850
131851
1 - 1 of 1 Posts
