1 - 18 of 18 Posts
Ok i got a 80 camino it had a 305 in it the guy i got it from said its a 355 how do i find out if its a 350 or 305 without pulling the motor or taren it apart??
Sent from my PC36100 using AutoGuide.Com Free App
NN
check the casting # on the block behind the driverside head where the engine bolts to the trans. some time around the 80 model yr gm started casting the displacement into the blocks there along with the casting # if no displacement there check on the casting #
Discussion Starter · #8 ·
Lol well i also own a 450hp evo so its hard for me to tell the difference boost throws u back v8 is just a constint climb for me but it needs work timming and vacum lines closed off.
It would have to be a pretty stout 355 to scare the crap out of you lol
1 - 18 of 18 Posts
