1 - 10 of 10 Posts
Hey,
Anybody got a picture of their tach filter wire going through the firewall on a 5th generation? I need to know which of the many factory dimples I need to drill out for this grommet. (Adding factory tach to a '79 with gauges, but no existing tach.)
On my car ('84) I poked the tach wire through the grommet around the steering column shaft. That way there's no holes to drill and seal in the firewall.
My tach filter has a very nice cone shaped rubber grommet on it. Looks like it would fit through about a 7/16" hole. There are several "predimpled" different places in the firewall which I know got drilled out from the factory as holes for various options. The rubber grommet will seal very well, as soon as I find out which one to drill.
Here is a picture of the tachometer filter and the firewall grommet in my 86 MCSS. When I put a tachometer in my 87 Elky I mounted it in the same location. Be careful you don't drill the hole too big.
Hole size for the rubber grommet?
Anyone know the actual size of hole for the tach filter grommet? That would really help me before I start going hogwild with the drill. Thanks, Ben
Boyd:
Does your factory tach match the year of your Elky? I've heard that in some of the earlier models (78-81) the circuit board on the back of the tach doesn't match the later years, thus if you get a tach from an '86 it's not compatible with an '81 Elky?
I'm interested in replacing the Non-Functioning Quartz Clock in my '81 with a factory tach but have heard that unless the tach is compatible with the Elky it won't work.
Anybody know for sure?
78-85 tachometers have a clock in them that sticks out the back.
86-88 tachometers do not.
I'm pretty sure the flexable circuit board on the back of the gauge pod is the same.
Discussion Starter #9
Ernie,
The tach I bought has the clock, and is supposed to be correct for my year. (1979) As for knowing whether it works right or not, we are a LONG way from finding that out! (Still in several hundred pieces in two different buildings.)
1 - 10 of 10 Posts
