1 - 8 of 8 Posts
while pullin out the motor in my 86 elk i poked a hole in the box under the hood where the heater hose goes how can i fix this
Clean the spot and use Long Hair Fiberglass then paint to match. The glass comes in a container sort of like Bondo and has a hardener like Bondo does. Its a little messy and sanding down the work you'll absoultly need a resperator but it will work and look fine after.
You can also use that stuff for small holes in the floor panels, its strong and doesn't rust.
Moderator
A resperator is a type of mask you use to keep from breathing stuff you shouldn't breathe. :cool:
Moderator
I wish everyone's questions were that easy to answer. :)
Moderator
You can also use a peice of fiberglass matting that will work really well.
1 - 8 of 8 Posts
