Starts easy every time and pretty decent mpg improvement. Unless your carb is perfectly tuned up too there is a good power benefit to be had.This sounds like a lot of hassle. What is the improvement over the original Rochester carb?
Which fuel pump are you trying to run? Also is your Spectra tank one of the '86-87 V6 EFI tanks? If it's not and it's a carb-style tank you'll probably want to at least get a Holley Hydramat connected to the pump.Will the fuel pump fit in the 22 gallon Spectra tank?
Well let me know if you need any other help with setting up your fuel system.Thank you. It is supposed to be for a 78 V-8. I'll have to get a Holley Hydramat connection.
^^^This too! I fabbed up my own as well. This is a must for the Sniper.From the linked article,
"After driving the car, we do have one critique. It appears that Holley has used a different throttle linkage arm on the Sniper that shortens the distance from the throttle shaft to where the throttle pedal connects. This quickens the ratio and increases the effort. This makes the car hard to drive in close traffic as pedal effort is dramatically increased. This makes it easy to open the throttle too far. Holley makes an adapter but we will probably just make our own extension."
So, the part they recommend for fixing the acceleration issue only works on the standard Sniper, not on the Sniper Stealth version.
