I an having a problem getting the hood to fit flush inside the fenders on the "78". I took the hood off to replace the passenger side fender. While I had it apart, I replaced the radiator support and painted it. The alignment with the front clip is good, but the hood needs to sit lower on the fenders. I even took the air cleaner off along with the carb stud in case it was hitting them. I have had the hood off before without running into this problem. Does anyone have any suggestions on how I can solve this problem?
