1 - 12 of 12 Posts
You can check with your local GM dealer. Here are the OEM part numbers for the molded hood insulation.
78-84 El Camino part # 12306178
85-87 El Camino part # 14085681
Both parts will fit OK. The only difference between the two parts is the location of the under hood light. This is the same part that Dixie Monte Carlo sells.
http://www.dixiemontecarlo.com/items/DM90206.html
Stay away from the cheap aftermarket die cut ones. They are junk.
I got one from Mike Montes for like $20 plus shipping. That is with new clips too. Worked perfectly!
I needed one last fall and found that the 14085681 part number is discontinued from GM. (it was in the OEHQ.com catalog but when i ordered was told it was no longer available). I found one still in stock at a nearby Chevy dealer but even at the this-thing's-been-here-for-ten-years-and-we're-happy-to-get-rid-of-it discount it was still $100+.
I'm pretty sure that 78-84 part number is discontinued too. if you can find either PN NOS at nearby dealer, i'd snap it up...
Butch I just replaced mine on my 87 I got it thru my GM dealer for about 90 bucks Sure does clean up the engine bay Jim:texas:
tsunamigregg, how's your hood insulation working out for you. Its been ten years! Wow! 😮
If you are still looking for a hood insulator, Look on craigslist in Baltimore under El Camino and you will find a brand new GM hood insulator part number 14085681 still in the box.
The guys name that has it is Richard and his phone number is listed in his ad.
He is a friend of mine and has some really nice Chevelle and El Camino parts for sale.
Thanks trismon for the tip. 😮
Terry.
1 - 12 of 12 Posts
