1 - 10 of 10 Posts
I need a assembly diagram of the horn parts in the steering column. I cannot find any diagrams on hw to assemble the horn parts the turn signals are working but i cannot fine a diagram showing me how to assemble all the other parts
1968 El Camino, 383, 5 speed
Basically the horn completes a circuit to ground through the horn ring to the contact in the turn signal. I’m not 100% clear on how the horn button itself goes back to ground. The circuit would have to pass through the steering stem and across the bearings.
Discussion Starter · #7 ·
66 El Camino standard steering wheel,The factory service manual does not show any illustrations of this wheel or where any of the horn and ring related parts go.I need a diagram of all the parts from the horn cap to the other side of the steering wheel,mainly how does the horn cap attatch to the horn ring.I also having a hard time finding a oem delco horn relay.reasonably priced.
Discussion Starter · #9 ·
Typically the Factory Assembly Manual is going to have the kind of exploded diagrams that you are looking for, not s Service Manual.
The factory assembly manual does not show any breakdown or illustration of the horn cap,horn ring,or any related parts.Page 428 shows the breakdown of parts for the wood steering wheel,I am lookong for the parts breakdown of the standard steering wheel.what parts are needed to assemble the horn ca to the horn ring and related contact parts?
· Premium Member
Well, if the resources you currently have don't show what you are looking for then you'll have to expand your research. Maybe check some other forums for Chevelles and other GM A-bodies as they may have the part numbers, exploded diagrams and step-by-step instructions that you are looking for.
Happen to have a few scans from when I was doing a 66. Maybe duplicates of the unwanted diagrams you already have. Also a couple old pics from when I was selling leftovers on ebay. Maybe will help to show some of the parts you need to pull together your assembly.
White Organism Map Font Parallel
Font Parallel Paper Illustration Line art
Motor vehicle Gas Circle Symbol Auto part
Packaging and labeling Event Transparency Font Plastic
1 - 10 of 10 Posts
