1 - 17 of 17 Posts
Hey I got a '81 Camino with the 5.0 engine and the horn worked when I bought it, but suddenly stopped. I tried checking out the fuse box but none clearly said "horn" and from what I saw online it doesn't look like there a fuse for the horn. Any help would be great! =D
is it an original horn ? may have fried
check your contacts in the steering wheel they can become corroded
and i am note sure if there is a fuse
:nanawrench:
When you try to honk the horn, is there a "clicking" noise from under the dash? If not, the relay has died. Cheap ($8) easy fix.
:poke:
Discussion Starter · #7 ·
Thanks for all the help, yes it's original
Do you remember the amps for that fuse?
There's no clicking, sounds like a plan, I've never done it before, know of any "how-to's"?
you have 3 relays under the dash (stock) 2 plug into fuse box and are for turn signals and flashers, they may be either round or square. the other one is square and when you unplug it, will have 3 prongs. get a new one at the parts store, and it wiill be easy to recognize the old one. The clicking noise is caused by the bi-metal piece inside closing the circuit, and making the horn honk when you push the horn pad.
:poke:
Discussion Starter · #14 ·
LOOK at this ↓
https://www.elcaminocentral.com/d2/articles/wiring/821.gif
The Fuse is Marked CTSY & is a 20 amp
Thank you so much! And everybody else too!!!
So I replaced this fuse, and although the horn still doesn't work, there's the "clicking" noise, what's that mean?
In regards to the interior lights, I don't know if they still work because a while back it wasn't turning off (even after car was off and doors were closed) so I just took out the bulb.
Discussion Starter · #15 ·
:poke:
Didn't see that before posting, so I guess just that new relay is all I probably need? (fingers crossed)
G
mine clicks, has a very very very faint sound of a dying horn who's been smoking cigarettes for the last 25 years. does the horn just die eventually? if so, where is the thing? I'm in an area where a horn is needed due to terrible drivers
Open the hood and look just the the drivers side of the hood latch. If you still can't see them have someone push the horn button while you are looking - ought to work?
1 - 17 of 17 Posts
