Ok so l took lumpy to the shop for some much needed tlc. When i got it back i had no horn. Upon further investigation i discovered a wire was touching the fenderwell. So when i blow the horn it was shorting out. Now no horn. I replaced burnt wires all fuses good it just clicks now. I did put power to the horns and they work so now what...thanks
Grab your multimeter and see if you have power at the end of the horn wire, and trace your way back to see where the power stops. There might be a hidden short elsewhere. If you don't have power anywhere on the wire, it might be a broken horn switch. I don't know, just something to try. :dontknow:
Thanks for the fast replies. Called the shop that did the work and they said bring it back
I think the tech left the 2nd horn wire unhooked and it touched the metal fender so we will see
again thanks for your time ....:beer:
