my horn stays on unless i unhook from relay not sure if this was a problem before i bought the car ive went thtu the column and cleaned it up everything seem to be ok , not sure if it could be the relay or steering column or because i havent got all the ground wires hooked up , im in the process of putting the car back together ,
Super Moderator
Take a good look at the wiring and the contacts in the column/wheel. If you have a wire that is grounding that contact out it will have that effect. I had a wire once that the insulation had worn off in the column. the horn would engage when I turned the wheel. super annoying but, fixable.
got r fixed, a little wire under the turn signal had grounded out causing the problem, Thanks everyone for the help :)
