I hope this is not a street motor...it won't live long above +8 boost...
You have a lot of Cam and Big valves...My guess is that you will not see much under 3500 RPM.
15 pounds of boost... I would hold the pistons to 8:1, you are putting a big reliance on the Fuel here...Real world and Simulators are two different animals...Go lean just a bit and its melt down time for those pistons. Better think of Titanium or Inconel ehhaust valves at 15 boost. You will see other issues with the heads....go with the thickest decks you can find...but nothing that money can't fix...Head Studs are a must on this one. And remember that Aluminum heads expand and contract at a different rate than cast iron blocks, so expect to check torque settings and replace head gaskets regulary.
Also, Waste Heat will be a major factor. The fuel burn you have will release massive heat, about half will go out the exhaust, so expect the first foot of the headers to glow red at 15 boost...25% of the heat is headed for the coolant...So think Massive and electric fans, idle the car cool before shutting it off etc "Heat Soak" will be an issue. I used an electric water pump on the fan thermostat (always hot, not on the ignition side) to circulate and continue to cool the block after shut down. This will require a dual battery system.
The oil will take the next 25%, so go synthetic and change it often! Repeat Often! You will need an oil cooler with a fan...and gauges everywhere. If you have 225F in the pan, you will be over 300F at the bearing
The list goes on and on...Big learning curve ahead for you as you go past 10 boost...
Fun to talk about all of this, and play with numbers on the computer....But in reality to be successfull plan to spend twice as much $$$ before this is all over, you are entering a whole new world at anything above +10 boost...
Best put a Rev Limiter on this one, with the Torque and RPM you will be building, miss that 2nd / 3rd shift just once and the whole thing will be in the bag...I know, as I have run Twin Turbos in the past...This kind of Fun never lasts long
