1 - 20 of 27 Posts
My recently acquired 1980 has had the engine replaced. I was told by the guy I bought it from that the owner previous to him had replaced with engine, transmission and rear end from a mid-80’s Camaro and that the motor is a 305. No paperwork or other details.
I would like to find out the exact year and model of the motor and transmission for the purpose of ordering parts and looking up specs. I do not see anything obvious on either. Can someone steer me in the right direction? Thanks in advance.
Hello,
Pictures of block and head casting numbers will help but these are generally hard to reach, rusty, dirty or blocked by other parts. A picture of the transmission oil pan will answer that question for type.
Camshaft specs will also be hidden. Note the spark plug type that is installed now. Does it have a GM HEI High Energy Ignition? I think many of those share common parts / ignition modules.
The carburetor might have a model number. If it is a 2-barrel Rochester and you post a picture, I can probably look it up in my Rochester book.
For the differential, I think you might be able to look that up by model number stamped on the axle tube. And once we know the transmission and its gears, we can take a drive and solve for the ring and pinion gear ratio using Internet calculators.
Thanks rick. I will try to get some pics tomorrow afternoon. Where would I start to look for the casting numbers?
I do know the carb is aftermarket, Edelbrock 1403 1907. The manifold is also Edelbrock, unknown model.
I was also told it has an aftermarket “mild cam” and that the transmission is 3 speed with no overdrive (automatic).
Crap. I will have to order some new gaskets before I pull the valve covers. Will be a few days. Thanks for letting me know where it is. I assume it’s on both sides so doesn’t matter which side cover I pull?
Discussion Starter #9
This is all I’ve been able to find so far. It’s on the bottom front drivers side of the motor.
131286
Discussion Starter #10
Here’s a better view from underneath. Definitely “784752” on the plate with “305” cast into the block nearby. Also a pic of the tranny pan.
131287
131288
Gonna' need a better pic of the trans pan closer to it. The center of that picture is the oil pan.
Discussion Starter #13
Got it! 14010203 hmm, just says 80-84 2 bolt 305. Does that mean from 80-84 we’re the same with interchangeable parts?
131289
Is there another letter where it says GM 5 0L?
You can now google the 14010203 and the LG and find more info on the engine (1980-84 Camaro not hi performance).
Many 305 proved to be reliable.
The later ones (about 96-98) in the trucks and SUVs had newer head designs.
Discussion Starter #20
I have read all I can find about this motor but still have an important question. I know this motor came out of an early 80’s Camaro but the info I’ve seen is this same motor was used from 80-84.
so, what I’m trying to find out is, is this motor the same as what would have originally been in a 1980 El Camino with 305 option? If not, what are the differences?
1 - 20 of 27 Posts
