21 - 27 of 27 Posts
"is this motor the same as what would have originally been in a 1980 El Camino with 305 option?"
Cars and trucks of that year used the same 305. The high performance L69 305 that came out in 1982 had different blocks/heads and was only available in Camaros and Trans Ams.
Yep, even when the Monte Carlo SS got a better 305 than the base Montes, Caminos were stuck with the base 305 even if they were SSs or Choo Choo SSs.
Patrick
My recently acquired 1980 has had the engine replaced. I was told by the guy I bought it from that the owner previous to him had replaced with engine, transmission and rear end from a mid-80’s Camaro and that the motor is a 305. No paperwork or other details.
I would like to find out the exact year and model of the motor and transmission for the purpose of ordering parts and looking up specs. I do not see anything obvious on either. Can someone steer me in the right direction? Thanks in advance.
get underneath with a wirebrush, a shop towel, a wet rag, and smart phone. clean the forward facing part of the axle with wire brush until you see stamped characters. wire brush it to get dirt/rust off, then use wet rag to get rid of rest of dirt, dry with shop towel then take a picture with your smartphone camera.
as for casting marks, you may need some grease cutter to clean up to see the stamped characters and the cast-in characters.
probably the best overall reference for casting numbers is Mortec.com
21 - 27 of 27 Posts
