1 - 3 of 3 Posts
Do I really have to take out the dashboard to remove the Actuator? *I removed the AC Heater console and the radio, now I can see the actuator, but can't get to it. How do I remove It?
Thanks, KB
if its the lower actuator on the left ??
take the lower vent duct off, see if you can get to it from there..
you may have to go thru the center AC vent for the upper one or both..
depending on where the rod to the doors go..
been too long cant remember..
before I removed the whole duct set-up, or dash,,
i'd cut a hole in the side,, replace the actuator..
then seal it back up with RTV sealer..
1 - 3 of 3 Posts
