I have the best luck with a box-end wrench, but if you do use a socket, go with a six-point like Jack recommended. It's really easy to tear up the hex on a brass fitting. If you use heat, how far away is the carb ? It's full of gas of course....
You also may be able to lay something flat across it, and whack with a hammer to jar it a bit. Not too hard of course....
