1 - 2 of 2 Posts
My 72 Elky SS dash had a radio or something attached to the area just to the left of the ash tray underneath the dash. Appears that the weight of whatever was attached broke off part off the under dash area about 2 inches in diameter. The prior owner had covered this area with an under dash steering column cover. If you can visulize there are two column cover plates sided by side and it looks pretty bad. I have been unable to find a cover for the under dash area at the online parts houses.
Does anyone know a way to repair this crack or is there an under dash cover on the market. All help is appreciated.
Moderator
Could you make a cover with thin sheet metal? Were in this great State are you?
1 - 2 of 2 Posts
