My car ran good for six months. Went for a drive car died. It has a two wire alternator that is still wired to an external voltage regulator. The car will start if the wires are removed from the alternator. There is a fuse wired into the positive terminal on the power wire to the alternator. When alternator is in circuit that fuse blows. Car has new ignition switch and a new relay for the horn. Any info is appreciated.
welcome Marty
is your alternator dash light in the same power wire with the fuse ??
I assume were talking about the excite wire, not the big charge wire ??
did you have the alternator tested yet ??
New alternator. No The fuse is on the heavy red from the positive side of the battery. Don't know why it is there. Ideas
on the older cars with a external regulator,
it was normal to have a Fusible link on the charge wire/side and battery side..
what year Elky / Cruck ??
what size is the fuse ??
what Amp Alternator ?? got a big stereo/amp ??
don't know why fuse would blow unless the Alternator is putting out too much,
or there is a short, or too much load..
if it starts and runs, and everything works with the Alt disconnected,,
start there..
i'v seen bran-new Alternators be bad,
usually its the re-built ones, that is really common now days..
