Has anybody used these (or something similar)? Just wondering if there are worth paying 2x more for the standard replacement.
TIA
It's supposed to make a big difference. Haven't done it yet myself, but I was also considering tall spindles instead.
But, you can go to Summit and get Proforged at the same price. ECS could be selling the same part... but how can you tell?
Upper - 101-10016
Lower - 101-10014
At least you'll get free shipping and better customer service from Summit.
1966 El Camino
The only improvement I'm aware of with the taller balljoints (when used in an oem control arm) is an improved camber curve. Drawbacks (again in oem control arm) is you will want an offset upper control arm shaft or more shims (or both) to align properly, on some cars (especially header equipped ones) this can pose a problem.
By itself an improved camber curve is good but in everyday driving will not really manifest itself in a significant feel of improvement unless you push yourself hard in corners.
Now all that said, combine the tall ball joint (or tall spindle for that matter) with an aftermarket upper control arm designed to be used for that application and you will usually see greater caster adjustability, a design that doesnt require a thicker shim pack and the camber curve and you will begin to see the difference.
Its definitly a swap worth doing if you like tossing your car into corners.
