Installation of the Sniper EFI system process
17447 Views 544 Replies 21 Participants Last post by  78 Elk
Next week I will try to get the new fuel pump and sensor in the fue tank. I plan to bolt the fuel pump on the sensor, if that’s the correct location for it.
541 - 545 of 545 Posts
I forgot to mention that on the handheld unit, all of the numbers were correct.
This is a dumb question. Can this type of thing happen if I start it up, just move it a little bit then shut it off? I did this several times over the last few days to get my lawnmower past it.
I got to say no.
Especially with Fi.
  • Like
Reactions: 1
Thank you for your help. The engine has ran great with the Sniper EFI system on it. This is the poorest this engine has ever ran.
I had a wild guess that maybe it was a plug wire with a loose connection. My guess was right. One connector moved quite a bit and another moved in little. I started it up and it was running great like it usually does. I hope to get it on the road tomorrow.
  • Like
Reactions: 1
