601 - 620 of 657 Posts
Discussion Starter #601
Heading out to Irwindale Saturday night.:whaasup::cali:
Break a leg!
looking good buddy, cant wait until I come down to CA some day so you can put the whooping on me.
Discussion Starter #605
I think I will start part 3 next season and run the Summit Series Bracket Racing.:popcornsmiley:
I bought a new set of Goodyear slicks, put in a new windshield re-painted the dash and inside the cab.
Thanks for watching I will be racing Thursday & Saturday night.
Discussion Starter #607
Will the light weight carpet help keep the tire smoke out of the cabin?
Did you decide against the forward facing hood scoop?
Hope it keeps the smoke out and keep it a little cooler inside. It's been too hot to really do anything so the scoop will wait till it cools down.
Dale is coming over for the weekend so If you want to come over Saturday I can BBQ some burgers before the track?
A
Maybe a rug and help, but not for long. It is necessary to solve the problem with the tires.: Hail2:
Is noon about right time to get burger?
Track opens at 2 PM, start testing runs at 3 PM.
Discussion Starter #611
Other than easing off the fuel pedal, what are your thoughts on keeping the tires from spinning through the 100-1320 foot marks?
Noon is good. I ran a 6.630 @103.63 last night not bad.:cool2:
Discussion Starter #612
New SFI 30.1 bolt-on bell housing.:cool2:
Discussion Starter #613
Ran at Pomona a friend gave me a pass at the last minute.
Discussion Starter #617 (Edited)
Was that at the HotRod & In-N-Out 70th Anniversary?
Isn't this the first time you ran the fairgrounds track?
Yes a guy gave me his pass that Friday night to run Saturday.
Discussion Starter #618
I just put in a 16v system and everything works better. I haven't had it at the track to see how it effects the spark but I can tell you the truck started on the first crank and idled from a cold start like it was already warmed up. Fans, pumps, everything works and sounds better.
I also installed a new trans.
Product Line:
FTI Performance TH400 Level 4 Transmissions
Summit Racing Part Number:
FTI-TH400-4
Number of Gears:
Three
Valve Body Style:
Full manual
Transmission Advertised Horsepower Rating:
900
Torque Converter Included:
No
Trans-Brake Included:
Yes
Lockup Compatible:
No
Transmission Pan Style:
Deep
Transmission Pan Material:
Aluminum
Transmission Pan Finish:
Natural
Tailshaft Length (in):
4.000 in.
Yoke Style:
Slip-on
Input Spline Quantity:
30
Input Shaft Material:
Hardened steel
First Gear Ratio (Automatic Transmissions):
2.48
Clutch Hub:
Steel
Transmission Case Style:
OEM
Transmission Case Material:
Aluminum
Transmission Case Finish:
Black
Transmission Shield Built In:
No
Flexplate Shield Built In:
No
Fluid Fill Location:
Case
Discussion Starter #619
O.k. Dale and I are on a new mission parts are on the way and the block will be going in for some work. Here's some of what's going on.:cool2:
Merlin II block bored to 4.60 14.5 compression. running race gas, Callies Crank4.25 stroke, Port & polish 119cc 320 alumn. heads, New Lemons 2-1/4 long tube headers, ARP 2000 Bolts, springs, Pushrods, Crower Crowbar Stud Girdles, Mechanical Roller lifters.
cam Basic Operating RPM Range:
4,600-7,800
Intake Duration at 050 inch Lift:
277
Exhaust Duration at 050 inch Lift:
291
277 int./291 exh.
Advertised Intake Duration:
309
Advertised Exhaust Duration:
323
Advertised Duration:
309 int./323 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.810 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.810 in.
0.810 int./0.810 exh.
Lobe Separation (degrees):
112
PISTONS
Bore (in):
4.600 in.
Bore (mm):
116.840mm
JE Piston Style:
Dome, with two valve reliefs
Piston Material:
Forged aluminum
Compression Height (in):
1.290 in.
Piston Head Volume (cc):
-44.00cc
