621 - 640 of 657 Posts
Discussion Starter #621
You'll have to get your professional license when you put that 565 in! :beer:
I think you accidently hooked your Texas Instruments calculator from college to Die Hard 12 volt instead of using the 9 volt transformer.
Unless you are using a slide rule. it's still just a 509 :borgsmile:
And the engine in my car is a 283. :tongue2:
Discussion Starter #626
Ok here's what we're doing right now.
motor upgrade just about everything replaced but the block.
Strip only running 114 octane:cool2:
Block
•Merlin II iron block,565ci. 9.800-inch deck height
• Fully machined and ready for assembly
• Cam bearings and freeze plugs installed
Reciprocating Assembly
• Callies 4340 forged steel crankshaft, 4.250-inch stroke
• 4340 steel I-beam connecting rods with ARP 2000 bolts
• JE forged pistons, -44 dome with two valve reliefs, gas-ported
Camshaft
• Clay Smith Cams Drag Race series mechanical roller
• Duration: .277 degrees/.292 degress @ .050-inch
• Lift: .800 inch
• Cam ground for a 1-8-7-3-6-5-4-2 firing order (swaps cylinders four and seven) for extra high-rpm horsepower and reduced crankshaft harmonics
Cylinder Heads and Valvetrain
• Brodix BB2-Extras aluminum, rectangular port, fully assembled
• CNC-machined 119cc combustion chambers
• CNC-machined 365cc intake/138cc exhaust runners
• 2.300/1.880-inch valves, 1.625-inch dual valve springs
• TD shaft mount rocker arms, 1.8/1.7 ratio
Trick Flow heavy-wall chromemoly pushrods
Oiling System
• Milodon Drag Race oil pan
• Moroso billet oil pump with pickup
Air and Fuel
•Brodix single-plane intake manifold, CNC port-matched to Brodix BB2-Extra Port and polish cylinder heads
• Quick Fuel QFX Series carburetor, 1,250 or 1,450 cfm, Dominator flange
• Aeromotive fuel pump/ pressure regulator
Ignition
• MSD distributor with 6AL/2Step
16v system Bat./Alt.
Other Items
• ATI Super Damper
• Cloyes Double timing set
• ARP 2000 fasteners, Fel-Pro and Cometic gaskets
• Clevite bearings
I see the plan for Merlin 2.0, just went to plan 2.1.
That is a jump to the Brodix BB2-Extras.
I figured CAlifornia 91 Octane wasn't going to play nice in 13+ compression.
Discussion Starter #628 (Edited)
The heads are being port/polished/gasket matched/5 angle valve job/spring upgrade and TD shaft Rockers. might as well do it right once.
Once that's done and we have the flow numbers we can have a custom cam built to match.
This build should net some good torque.
Discussion Starter #630
Discussion Starter #631
Heading out to Fontana with Dale Saturday for the first runs on the new motor.
Discussion Starter #633
What time?
I will be at Dales at 6am should be at the track before 8am racing starts at 9am. Brad and his son are going to be there. I didn't know if we were going until this afternoon. It would be great if you could join us. I'm going to the store right now but I will check back shortly.:You_Rock:
Discussion Starter #635
Discussion Starter #637
From your Left to right:
Robert, Brad, Dale working on the new 1250 CFM carb and timing.
Changing jets at the track.
Cool pictures. Dale and I think we figured it out my MSD box is going bad. Nothing to do with the engine just electrical. :cool2:
Shear Performance in Costa Mesa tuned my '70 in 2015. I asked for a bench mark on the timing before they changed it. They said it was moving around and not stable. Idle had to be 950 RPM or above. Part of the work that day included removing the blower intake manifold. They then checked the HEI and could see lots of play in the distributor shaft to gears. Changed the HEI and could tune it and idled at 700 RPM. Might be worth a check on your dizzy too.
Discussion Starter #639
I just put a new dist. gear and shimmed it .010 yesterday. I'm going to pull the MSD box out of the 69 and see what happens.
Discussion Starter #640
Must have been the altenator I changed it back to the 12v. it idles at 700rpm in gear and the fans on. Revving it up sounds clean all motor. I hooked up both my MSD boxes and the motor ran the same. A/F AT 15.1 @ 700RPM
