1 - 2 of 2 Posts
I'm kind of poor and looking to piece my el camino together over time. I was thinking of putting a 5 spd transmission in it instead of traditional automatic. My thoughts were with the tremec tko 600. I just wondered if there is a way for me to run that trans with a 4.3l motor and stock rear end?
The 4.3 has the standard chevy bell housing bolt pattern. A bell housing, flywheel and clutch assembly is a start. Clutch linkage (mechanical or hydraulic). I'm running a TKO600 and you will have to cut the tunnel to get the drive line angle correct but it should work just fine if you can round up the necessary parts and get them installed correctly.
1 - 2 of 2 Posts
