yes, it eliminates the rag joint & makes the streering much tighterI didn’t know the Jeep XJ (Cherokee) steering shaft was an upgrade.
on the jeep shaft you have to make a little notch for the bolt to go thru, very easyIs this a direct replacement or is there cutting and welding involved?
Tom
👍😁on the jeep shaft you have to make a little notch for the bolt to go thru, very easy
Not sure on the new crown part if you have to do that ?
here is some info
Jeep Steering Shaft Upgrade
I have a few Jeep Steering Shafts for sale. $60 each Shipped USPS (lower 48 states). These shafts make a great upgrade over the old rag joint setup. Tightens up the steering and gives more clearance along with a cleaner look. These are compressed, cleaned, painted, greased and ready to...www.elcaminocentral.com
