You went from a 350 to a 350...My question relates to going from a 305 to a 350....Water pump,can I reuse the old one?Aside from gaskets,fluids and belts,What else needs to be changed????Harmonic balancer???I plan on changing the intake manifold.I'd like to keep the old quadrajet...Will my old computer still work the same...Not changing tranny at this time....
Year: 1987
Model: El Camino SS
Region: 18(CA)
NECOA #: 10110
EL S ONE will become famous soon enough
Default 350 build
I found this article in Chevy High Performance Magazine. It is written by Kevin McClelland. I would do this. I throughly believe in his advice.
Simple Crate
I have a daily driver ’87 El Camino with a tired 305. I’d like to put a crate 350 in it. Nothing radical, just a stocker with maybe 200-250 hp. It also must pass California smog. I remember reading an article (four to five years ago) about a crate motor with an Edelbrock manifold, carb, and a 305 cam, but I no longer have the magazine. Any suggestions? Thanks,
Doug Cole
Via email
Doug, for a simple crate 350 engine swap we recommend going with a factory GM Goodwrench crate engine. GM has been offering this engine forever. They were originally called the Target Master Crate engine and were renamed when GM started branding itself Goodwrench. GM has built millions of these engines over the years, and we’ve used them for truck and passenger car replacement engines, and whipped them on the dyno for run after run, without even a whimper. Give our good friend Ken Casey a call at the new John Elway Chevrolet (800.345.5744) for pricing and freight for a 350 Goodwrench engine (PN 10067353). This is a direct replacement engine for ’71-85 applications. This will drop right into your ’Elco and all you’ll need to pick up is a standard-balance 153-tooth flexplate (PN 471529). Yes, you will need to truck the engine out from Colorado, but Casey is very competitive with his pricing, we’re guessing under $2,000 for a brand-new engine. All this and a factory warranty on the engine for two years and 50,000 miles!
As you said, you had a story of a crate with a simple camshaft swap and manifold. We’d go with an Edelbrock Performer EGR manifold (PN 3701), and the matching camshaft (PN 3702). This camshaft shaft specs out at 194/214 duration at 0.050-inch tappet lift, 0.396/0.442-inch max lift, and is ground on 112 centers. You will notice that this is a very short camshaft. It was originally developed back in 1985 to work in the LG4 305s, which were computer controlled. Oh yeah, that’s the engine that’s in your ’Elco. This camshaft will work in concert with your factory computer calibration and pass emissions in the state of California. The short nature of this camshaft will produce great throttle response and make outstanding slow-speed torque. The engine will make strong power to 5,000 rpm and produce about 250 hp through the stock exhaust manifolds and cat.
If you wish to step up to headers, you could also add the Edelbrock TES system, which is emissions legal in California and will boost your peak horsepower on this package by around 20 hp. The TES system for your LG4 305-equipped El Camino is PN 68783. This kit will bolt right in to your El Camino’s factory 21/4-inch catalytic converter. If you wish to step up the exhaust to the high-flow Corvette four-bolt–style converter, go with PN 68793. This, in conjunction with a nice after-cat exhaust, will round out your emissions-legal engine swap nicely.
We know this engine won’t turn the world with its sheer power, but it will give you a great daily driver that will get decent gas mileage and produce over 100 hp more than the stock 305! This will make a big difference in the fun factory with your ’Elco. Good luck! CHP
Sources: edelbrock.com, elwaydealers.com
