Found this while looking up lightbulbs. You can actually plug in year/make/model and it will tell you all the bulbs you need and where! I'm thinking someone may want to jump out there, look up their specific vehicle and then cut/paste the data here. And while it may be Sylvania's specific product, you'll notice it references the lightbulb part#. Just having the part# available when you goto swap meets and get the cheap LEDs will be nice
www.sylvania-automotive.com
Here's 1986.......
1986 Chevrolet El Camino
Sylvania Automotive Bulb Replacement Guide
Need to replace a bulb? SYLVANIA's bulb finder will help you find your correct replacement bulb for your vehicle and help determine which product family is right for you.
Here's 1986.......
Application | Part # |
Headlight Bulb High Beam | H4651 | Bulb Available | Bulb Available | Bulb Available |
Headlight Bulb Low Beam (Compare to original - Option 1) | H4656 | Bulb Available | Bulb Available | Bulb Available |
Headlight Bulb Low Beam (Compare to original - Option 2) | H4651 | Bulb Available | Bulb Available | Bulb Available |
License Plate Light Bulb | 194 | Bulb Available | Bulb Available | Bulb Available | |||||
Turn Signal Light Bulb Rear | 2057 | Bulb Available | Bulb Available | Bulb Available | Bulb Available | ||||
Turn Signal Light Bulb Front | 2057A | Bulb Available | Bulb Available | Bulb Available | |||||
Tail Light Bulb (Compare to original - Option 1) | 194R | Bulb Available | Bulb Available | Bulb Available | Bulb Available | ||||
Tail Light Bulb (Compare to original - Option 2) | 2057R | Bulb Available | Bulb Available | Bulb Available | Bulb Available | ||||
Side Marker Light Bulb Front | 194 | Bulb Available | Bulb Available | Bulb Available | |||||
Side Marker Light Bulb Rear | 194 | Bulb Available | Bulb Available | Bulb Available | |||||
Parking Light Bulb (Compare to original - Option 2) | 2057A | Bulb Available | Bulb Available | Bulb Available | |||||
Parking Light Bulb (Compare to original - Option 1) | 194 | Bulb Available | Bulb Available | Bulb Available | |||||
Back Up Light Bulb | 1156 | Bulb Available | Bulb Available | Bulb Available | Bulb Available | ||||
Brake Light Bulb | 2057R | Bulb Available | Bulb Available | Bulb Available | Bulb Available |
Turn Signal Indicator Light Bulb | 194 | Bulb Available | Bulb Available | Bulb Available | |
Radio Display Light Bulb (Compare to original - Option 2) | 194 | Bulb Available | Bulb Available | Bulb Available | |
Radio Display Light Bulb (Compare to original - Option 1) | 73 | Bulb Available | |||
Radio Dial Light (Compare to original - Option 2) | 194 | Bulb Available | Bulb Available | Bulb Available | |
Radio Dial Light (Compare to original - Option 1) | 73 | Bulb Available | |||
Parking Brake Indicator Light Bulb | 168 | Bulb Available | Bulb Available | Bulb Available | Bulb Available |
Courtesy Light Bulb (Compare to original - Option 2) | 89 | Bulb Available | |||
Courtesy Light Bulb (Compare to original - Option 3) | 906 | Bulb Available | |||
Engine Compartment Light Bulb | 93 | Bulb Available | |||
Dome Light Bulb | 561 | Bulb Available | |||
Glove Box Light Bulb | 1895 | Bulb Available | |||
Clock Light | 168 | Bulb Available | Bulb Available | Bulb Available | Bulb Available |
Ash Tray Light Bulb | 1892 | Bulb Available | |||
Instrument Panel Light Bulb (Compare to original - Option 3) | 194 | Bulb Available | Bulb Available | Bulb Available | |
Instrument Panel Light Bulb (Compare to original - Option 1) | 161 | Bulb Available | |||
Instrument Panel Light Bulb (Compare to original - Option 2) | 168 | Bulb Available | Bulb Available | Bulb Available | Bulb Available |
High Beam Indicator Light Bulb | 161 | Bulb Available |
