Howdy folks.
The passenger window in my car has been leaking water in for a few years. My carpet on that side had a pretty nice collection of species of moss growing on it. So I cut out the carpet and padding yesterday to address any rust.
I'm going to cure the rust and coat the floorboard in bedliner. Eastwood Rust Converter and Rustoleum Bed Liner, both in spray cans. I think this should sufficiently protect the floor from further damage during rainy weather, as well as provide a suitably grippy floor material.
The bits of rust are spotty and scattered across the area, with fair size bits of unmolested floorboard between them. I've read that Eastwood Rust Converter does not stick very good to painted, clean, or otherwise non-rusty metal.
Should I tape off the rust areas and spray the bedliner first? Should I spot-spray the rust first, then use acetone to wipe down the areas that didn't stick?
I'm leaning towards the later, so that the seal formed by the bedliner is not broken by any bits of tape that get stuck in it.
Maybe the Eastwood guy will chime in here!
