1 - 8 of 8 Posts
Hey guys
Im having troubles finding the coil to hook my tach too. Anybody got pics?
If you have a HEI type distributor the coil is built into the distributor cap .Mine has a plug in socket next to the plug in for the 12v feed,on the driver side of the distri.
Agreed...hook-up is in the cap next to the pink hot wire
its the spade terminal on the left(front) the one on the right(back) is the ignition power(there are two)(don't mess with the plug coming up from the distributor to the cap)the red wire(or pink) will be the ignition, (it's right beside that one)
1 - 8 of 8 Posts
