1 - 2 of 2 Posts
Just a curious question for the correct type of antifreeze to use for the 1994/ caprice / LT1. i'm using the : NAPA Antifreeze, PN # NAF 1GAL. since i changed out the OEM aluminum core/plastic tank radiator to an all aluminum, would there be a change in the antifreeze i use? i wouldnt think there would be but just wondering if there was another type considering all the different mixtures/additives like:
green or yellow coolants use silicates
orange or pink including DexCool coolants use organic acids
i guess i would need to ask what specifically works best in your opinion in your LT1 (what brand you use)
Is the mixture/additive decided by the MFR. based on any single main component( the reason why they choose that type) like radiator, pump, block, heads?
thanks
https://www.napaonline.com/en/p/NAF1GAL
1994 Caprice OEM Coolant bottle cap had a green dot , which I guess you would use {green} Prestone type antifreeze. Later Model Caprice's used that DEX-Cool product {Orange in color } . !00,000 mile coolant . Coolant bottle cap had orange dot on top . 50/ 50 Mix in my opinion ...
1 - 2 of 2 Posts
