1 - 1 of 1 Posts
If you look under the drivers door on mid-90s thru early 2000s S-10/Sonomas, on the inside of the frame rail there, there is a neat little bolted on bracket that holds the fuel filter. Looks like it would even bolt to the front of the block near the fuel pump on an elkie, to keep it from laying against the engine. What a coincidence........or not.
:unsure:
1 - 1 of 1 Posts
