1 - 15 of 15 Posts
· Premium Member
I just replaced the electric choke element on my Q-jet. Got it from Advance Auto. The electric type is easier to deal with than the hot air or divorced type.
If there's a problemg getting it adjusted, maybe the climatic spring is bad. A new unit would fix that. And simply adjusting the choke closed with a cold engine , is a place to start.
To answer your question you PM'd me installation consists (roughly, as always, RTFM!):
1. Pulling off the black cap on the carb, where the wiring connects.
2. Reinstall using the manual choke.
3. wire the mechanism to somewhere in the cab. I chose just below the parking brake release.
4. use the enclosed hardware to hook it up to the choke.
Pulling it out ~3/4 inch closes the choke and pushing it in opens it up. Fairly simple process. Might be easier just to fix the electric. Mine was kinda borked so I just did it in a way that guaranteed it would always work.
1 - 15 of 15 Posts
