1 - 3 of 3 Posts
ok guys i have a question. it might be silly iy might not be i dont know,
i was taking all the emmisions stuff off and i also changed the valve cover gaskets. while i was in there i glanced at the casting numbers.
one was 462624 and one was 3932441.
is this normal? they are both 76 chambers and maybe have the same valves, so CAN YOU MIX THEM? IF NOT WHY ARE THEY MIXED ON MINE>>
shouldn't be a problem --i doubt one side know what the other is??:poke: whats Al Whore going to say about removing the smog??:dontknow:-glenn
the 441 is a better head...my wifes camino has 2 different heads on it too...when i put plugs in one side takes 5/8" & other takes 13/16 plug !!:???:
1 - 3 of 3 Posts
