I haven't seen many cars with the top supports, prolly because of clearance issues with parts. Those are usually for high HP twister torque type motors. Don't think the top bars do too much for suspension. I could be wrong though.
are you in a state that requires parking brake to function at annual inspection? if so, I hope you have a solution to the rear blazer parking brake issue. solutions do exist but you will need to manufacture the bracketsUpdate. Today I order my rear bar (hellwig) and HD springs. Shocks will be ordered tomorrow. Plan to drop rear end this weekend and start on the rear blazer brake conversion. Pics coming soon.
What do you mean? Are you referring to the brake line bracket?are you in a state that requires parking brake to function at annual inspection? if so, I hope you have a solution to the rear blazer parking brake issue. solutions do exist but you will need to manufacture the brackets
nope, cable for the parking brake. if required, you'll have to rig it up somehow. IIRC the geometry for the rear brakes is all wrong and you can't just bolt-on the blazer rear brakes and expect the parking brake to work.What do you mean? Are you referring to the brake line bracket?
Are you referring to the brake line bracket or brake light?are you in a state that requires parking brake to function at annual inspection? if so, I hope you have a solution to the rear blazer parking brake issue. solutions do exist but you will need to manufacture the brackets
neither, I am talking about the metal cable. when you press down on the Parking brake, the cable is physically attached to the rear drums and causes the rear drum shoes to expand out against the brake drum. you pull the Parking Brake release and it releases the brakes.Are you referring to the brake line bracket or brake light?
joe, youshould have some rubber stand-offs at each front hood corner. this helps stabilize the hood and orevent wobblingThe front corners of my hood move a lot, above 60 mph. Or is relative to the fender movement?
Do any of you know, will adding the core to fender supports reduce this movement?
No, it's the rubber bumper stops in the header panel. If they are worn/cracked, old or basically moved to the point of being useless, you'll get rocking from side to side using the latch as the fulcrum. They should sit the hood flush at the corners plus a hair so there's a slight tension when the hood is latched. If the hood latches high, that might need adjusting or the front clip raised a hair to bring everything in line. You'll know if one fender is out as that corner will be lower/higher than the rest of the hood.The front corners of my hood move a lot, above 60 mph. Or is relative to the fender movement?
I'm in Louisiana brother. Not sure, I dont think its required. Just parking lights.neither, I am talking about the metal cable. when you press down on the Parking brake, the cable is physically attached to the rear drums and causes the rear drum shoes to expand out against the brake drum. you pull the Parking Brake release and it releases the brakes.
it is also called an Emergency Brake because if you were to lose hydraulic brake fluid pressure, the only brakes you have left are the rear drums, and you stand down on that Parking Brake pedal.
some states (Texas is one) require a vehicle to have a Parking brake (all vehicles have a parking brake) at annual inspection. if your state ( you never told us where you live) requires it, you will have to have it working before you go to get it inspected.
Just curious. So what's your solution to that? Keep drums in the backParking brakes come in handy, especially if you need to jack up the front end, can't rely on the tranny since the tires will rotate an inch or two before locking up, and not everyone has a Posi rear, so jacking up the drive tire can make a person nervous.
depends on why you are considering the rear brake changeJust curious. So what's your solution to that? Keep drums in the back
