1 - 2 of 2 Posts
Does anyone know of a competent shop that knows how and is willing to shim out my front end to spec?
I've taken it back twice to my local tire guy , both times the steering wheel is not centered and it pulls to the right!
2nd time it came back worse than the 1st time.
The Tech. was adjusting it and test driving it and would come back shaking his head as if he was stumped.
Would bad front shocks cause a pull to one side even with a good alignment?
Also I will check the frt wheel bearings for play.
Participating Member
Talk to SoCal Elk... best in the business!
btw... a pull (without braking) is a symptom of alignment. Shocks will not effect alignment.. tire wear and handling, yes... alignment, no!
1 - 2 of 2 Posts
