Will a 285/30/18 or 285/35/18 fit my 5 gen with no rub scrub in the rear
I run 245/45ZR18 18X8 RIMS NO RUB NORMAL DRIVING AND THE ONLY RUB IN THE FRONT IS IF YOU TURN THE WHEEL ALL THE WAY.:nanawrench:
Generally the widest you can run on a 5th gen with minor mods is 275, they are really tight. Normally to run 285 or 295 requires mods to the frame
Thanks I'm not gonna mod the frame and I just want the 285 in the rear I found a used one for twenty dollars and was gonna tests it but guess it won't work. I'm running 235/40/18 now and wanna better look for the rear :nanawrench:
