1 - 9 of 9 Posts
Hello friends. When I bought my 72 El Camino the guy I got it from had 255/70R15 tires all the way around. When I got it running it seems as though I'm getting a lot of tire rub when I turn the steering wheel to the left or right. Even the back tires sometimes rub if I'm backing down a hill. I'm sure they're too big so I was wondering if anyone knows the proper size tires that should go on these vehicles. Thanks in advance for your knowledge
Factory tires were G78 x 14. SS used G70.
Todays equivalent would be 225/235-70 x 14.
If you are keeping the 15" wheels a 235/70 or 245/60 x 15 will be satisfactory and keep you out of trouble Others run larger tireswith success but may have special wheel offsets to do so.
Yes wheels make a difference. I had 255/60/15 on the rear of my 70 mounted on Corvette rally wheels and they would rub a bit if I loaded it down but normal driving without a load was fine, and 225/70/15 on standard rally wheels for the front without any problems.
My 1965 El Camino (not SS) had too wide of tires 255/70/15 and they rubbed constantly. I changed to 225/70/15 all around so I can rotate them and I have been extremely happy with them. No rubbing and it’s amazing how much anxiety there was driving when I had on the 255s. That all went away and it’s SO much more enjoyable to drive.
I have 245-60-15s on the front of my 72 mounted on Torque Thrust D wheels. The wheels are 8" and I believe are 0 offset. The wheels were on the truck when I got it. No rubbing in the front.
On the rear I run 275-60-15s on the same 8" wheel. When I first put them on, I had one side catch the inner fender and cause a rub on hard right turns. A little massaging on the inner fender and no more issues out back. I do also run air shocks on the rear as well so If I need to carry a load, I can adjust the ride height.
1 - 9 of 9 Posts
