Hi folks. So once in a while my Elky wouldn't start unless I wiggled my shifter on my steering column and it eventually wouldn't start at all over time. I decided it was the neutral safety switch because it started up right away when shorting the purple wired plug that goes to it.
I didn't have a switch to replace it with but I took the old one apart, cleaned the contacts and put some dielectric grease on. Aside from the contacts for the reverse lights being slightly worn, everything else appears to look good. Now it works fine.
My question is since it's working like a champ should I just leave it alone or replace it with a new switch since they are pretty inexpensive. I always try to use an original part as long as I can since a lot of stuff seems to be built cheaper and in china.
