Thanks I was freaking last night after all the questions asked before buying the motor the all of a sudden nothing was going to fit. I can see the light again after a couple hrs. of sleep and make this project an all new acc.'s for the motor and take my time till the 305 dies or who knows maybe me first the way it's running now it could go another 300k easy. My compression is correct and when I pull the plugs they always look like the should no oil or build up on the tips just look like they been used.Robert, the intake mod is a piece of cake. I did mine with a Dremel. The difference is that the 4 center bolts on your heads now are made to go in almost vertical. On the older style heads they are angled. Once I ground out the holes in the intake , I cut some small pipe to match the angle or the intake and the installed the bolts. It sounds harder that it really is. So one tool you'll need it a Dremel. The flex plate is also easy. There's 6 bolts that attach it to the end of the crank. Just order one from Summit or Jeggs. There's no internal work involved. You've already mentioned getting a torque wrench so let's get this baby going. No fear. Also, I bought the wiper arms from G-boz. He's shipping today. As soon as they arrive I'll send the same box to you with the drivers side arm still in it. Thanks..
Robert:texas:
