1 - 20 of 27 Posts
Discussion Starter #1 (Edited by Moderator)
I have been looking for weeks at different styles of wheels and non of them fit the exact look I want unless I spend thousands of $$$. The closest thing I found are Vision 143 Torque wheels. I wanted something in a 17 or 18 and staggered. My question is.... Will the below wheels fit? I believe the fronts may rub or require slight work to fit but my main concern is the backspacing on the rears.
Fronts: 18x8.5 with 4.5BS
Rears: 18x9.5 with 5.25BS
127367
Year would help. My 87 has 16x8 with 4" bs and 235/60/16 and there is 3/8" clearance from sidewall to frame. UMI has a frame notch kit that doesn't require removing the body and will get about another inch inboard.
I may have posted this twice... I tried on my phone and kept getting error messages so I opened another on my computer. So sorry for that.... yes it's an 86. Thanks for the info!
There was at one point a pretty good write-up here on this site about 5th gen tire/wheel fitment. Maybe search "5th gen fitment guide" and see if you can find it.
See if this article by BillyJack helps out.
'78-'87 Tire / Wheel fitment guide - Read before buying!
Discussion Starter #9
Thanks. I did read through the fitment guide. I was still having trouble figuring out if a 18x9.5 wheel with 5.25" backspacing and 0 offset would fit. I took a plub Bob inside the fender and measured to the frame. I also measured from the hub to the frame and I believe I will have about .5" clearance on each side. I was hoping someone out there was running something similar so they could confirm it will work.
@JEBS86 What's the plan? I ask because I'll be going through the same soon.
Do you continue to measure, do you just go to a tire/wheel shop to test fit wheels?
Do you order online in the hope that you don't run into clearance issues?
@Mechanic....sweet! Killer stance.
So I did a lil crawling and picturing. Lighting Suxs. Approx 2” clearance where it rubs fender lip. Running 8psi. Car really doesn’t look that jacked like the pics I posted. Note the Wilwoods. I’ll measure the space between interior rim to brakes on another day.
Is the Superlift sticker on the door jamb factory applied? Note it’s states 10psi normal psi. And you adjust according to load you plan to haul.
Discussion Starter #14
I am happy with my initial measurements. Everything should clear depending on tire sidewall. Worst case I will roll the rear fender a hair, or run thin spacer. Spacer being last resort.
Make sure you have your alignment set for positive caster and negative camber with those low profile tires or you could have some dangerous stopping issues..
Frankly, I like the first and second generation Chevrolet Rally wheel in 15 x 7...
Can't speak to 18X9.5" but I kept 18X8" with a good sticky tire so I could do 4 wheel rotation. These are a Rocket Racing version similar to the ones you are looking at.
127703
@kat0069. Gorgeous...could you post close ups? Is 3.75” backspace the “average” for 15” rims? What tires what airpressure?
is she back on the road, Kat? I hope so!!
Discussion Starter #20
I currently have stock brakes on, but I will install 2000 corvette brakes once I get my BMR stage 2 suspension kit.
1 - 20 of 27 Posts
