Hello all and thanks for reading this... I am stumped. I have an 86 with the 4.3L FI V6 and it will not start at all. The engine turns over beautifully but I am NOT getting fuel to the injectors. I replaced the electric fuel pump a few years ago and change the filter regularly. I removed the filter to check for a blockage and it was fine. I do not have a fuel pump pressure gauge but think I should be able to check it without one to see if it is getting a signal. I have never heard the system charge like some people talk about so I cannot answer if I hear anything when I turn on the key. I also have no idea how to test the fuel pump relay. I know that the ECM is involved with a lot of this but it was replaced a few years ago too and I do not think that this is part of the issue. What I need are suggestions for checking the relay and pump for signal issues before I just replace them both. I have not been getting any check engine signals and was wondering if I could possibly have any wiring issues I should check as well. I have a reoccurring problem with brake light failure and have a steering wheel harness issue I think but this does not seem to me to be something I should check now. I like to fix what is wrong and not jump in and just replace suspected parts. Any tips anyone and or additional things you think I should check? Thanks again, Dave
