I have an issue with the heater not coming on at all. The fuse is good but it looks like there’s a wire that’s not connected not sure where it supposed to go but according to the wiring diagram it’s supposed to go to the blower motor which seems not to be a connection. Can anyone take a look at this picture and see what’s not quite right the orange connector I believe should plug-in somewhere
126859
I think the orange wire goes on the connector closer to the blower motor..
not sure what the other black wire is for..
the black wire with the noise filter on it, may be the ground for the blower...
Neil/464Elky will probly be on in the morning, see what he thinks too...
I have not seen a non-AC car for a while...
any extra non-original looking switches inside??
heres a wire diagram
126873
Ok thanks so much. After further investigation I found the plug underneath where the orange wire connects as in the diagram. I don’t know why the PO would disconnect? Seems to be working fine.Appreciate the Diagram and response.
