I took my 79 out for it's weekly drive and after stopping at the store I went to start it nothing happened.
I tried to jump it but still nothing.Battery is fully charged.Headlights and dash lights work. Wipers and fan do not come on when key is on.
On the way there the only thing I had on was the heater fan.
There is no voltage at the solenoid when the key is turned to the run start position.
So I figure it's the ignition switch on the column.
Everything I read said there are 2 screws attaching it to the column with the dimmer switch piggy backed to it. So I lower the column and remove the 2 screws but the switch will not come out. It appears the switch is riveted to the column. Anyone ever see this? Now it appears I will have to completely remove the coulmn to get drill out this rivet. Does anyone have complete instructions on removing the column?
