1 - 3 of 3 Posts
OK i am trying to adjust the neutral safety switch on my 1987 elky. I have two manuals one says there is a screw i have to remove and then slide the switch to the low gear position, the other manual does not mention a screw. Is there a screw i have to remove before i slide the switch. can anyone help here
There are two screws that mount it to the column. Just loosen them both a little and you can slide the switch back and forth to adjust it.
1 - 3 of 3 Posts
