21 - 40 of 76 Posts
Discussion Starter · #22 ·
This thing is keeping you busy!
that too, plus I actually have to work for a living, get a teenager to select a college, go on college visits, start cleaning out the house to sell it in a couple of years, assist with the live-in handicapped mother-in-law, take my Masters degree classes....... it never seems to end. there's no Me time.
Discussion Starter · #23 · (Edited)
PARTS UPDATE 8/30/21 (I've gone thru the items)
btw, some of these items will be $$ to ship. I've tried to price items accordingly so that item-price + shipping still saves you money, so you can get an OEM part that is no longer made.
Body
Front grill - PENDING
Body trim for a two-tone (all of it from front to back) - AVAILABLE , $100
Caballero grill script - AVAILABLE , $60
Rear window - AVAILABLE , $100
Quarter windows - AVAILABLE , $40/set
Door glass - AVAILABLE , $20/set (both unbroken as far as I know, psgr side good)
Psgr Door - AVAILABLE , $20
Front Bumper w/bumperettes - PENDING , $120
Front License plate bracket - AVAILABLE , $5
Under The Hood (305 v8)
Windshield Washer jug - AVAILABLE , $20
Air Filter snorkel Intake - AVAILABLE , $10
Coolant Overflow - Broken
Vacuum ball - AVAILABLE , $20
Charcoal canister - AVAILABLE , $10
Delay Wiper motor w/linkage - AVAILABLE , $15
...this DOES have Wiper Delay! AVAILABLE , $5
(the wiper delay is this style,Standard Motor Products DS-414 Standard Motor Windshield Wiper Switches | Summit Racing)
A/C compressor - PENDING , $40 (cut the condenser radiator off and it was still pressurized, should still be good)
.........(appears to be an aftermarket 4 Seasons compressor)
A/C condenser/radiator - PENDING , $20
Cast Iron Exhaust manifold - AVAILABLE , $30/set (has the surround shield to help heat up air for the intake)
various Engine Brackets - AVAILABLE , $5/ea
Interior
Rear headliner trim piece - AVAILABLE , $5
Radio - AVAILABLE , $FREE (because it was under water)
Door sill plates - AVAILABLE , $5/set
tilt Steering wheel and/or column - AVAILABLE , $40?
Glove box - AVAILABLE , $5
Instrument gauges - AVAILABLE , $10
This has a clock in the gauge cluster!
SOLD ITEMS
Front clip, fenders, hood, etc - SOLD
Two-piece fan/engine shroud - SOLD
GMC on tailgate - SOLD
GMC Hood ornament (needs work) - SOLD
Rear window trim - SOLD
Front windshield trim - SOLD
Chin radiator spoiler - SOLD , $25
Cruise control transducer - SOLD , $50
Radio, dash surround - SOLD
Radio, mounting bracket - SOLD
Dash wood plaque with Caballero script - SOLD
Body
Interior
SOLD ITEMS
Body
Interior
SOLD ITEMS
Body
Interior
SOLD ITEMS
Hi,
My name is Al & I'm interested in the Body trim for a two-tone (all of it from front to back) - AVAILABLE , $100
How can we make this happen.
Discussion Starter · #25 ·
Hi,
well, there's a couple of questions to answer first:
1) where are you located? I'll need a home mailing address and a cell phone contact #
2) since you are a new unknown member on this forum with no history, I only take US Postal Money order, which then has to clear first, and then I send the package
If you are ok with those conditions, let me know.
Thanks!
Thanks!
Hi
My address is: Al Mailhiot
25 Norman Drive
Framingham, MA 01701-4447 (978)703-2667
I have no problem with the money order. I am a new member to this forum. I have an '83 Caballero I've been fixing-up. I look forward to doing business with you.
Discussion Starter · #27 ·
Hi
25 Norman Drive
Hi Al, Tom here. Looks like you've had your Caballero a long time (since at least 2011). Looks to be in pretty good shape, what's wrong with what you got?
[/QUOTE]
Hi Tom, I've had my Caballero since '09. However, I'm a little puzzled I haven't posted any pics yet and I'm not sure how you knew I've owned it for a while. Unless you have me confused with someone else. I was the one interested in the 2 tone body molding. As for what's wrong I need a fresh paint job. I'm in the process of converting my bench seat into buckets and a floor shifter. With the interior removed I've found a couple of small leaks. The 305 4bbl runs good. Has 96,000 original miles. I rebuilt from the heads up. I have a small oil leak, looks like the rear main seal. Hope to hear from you soon about the molding....give me a call when you get a chance.
1987 GMC Caballero, 400 HP 350, Holley Sniper EFI, 200-4R
I may be able to help you, in a couple of weeks. I'm removing my rear bumper and installing a roll pan. If I don't need that filler piece, you're welcome to it.
Body
Body trim for a two-tone (all of it from front to back) - AVAILABLE , $150
Tailgate - PENDING
GMC on tailgate - SOLD , $60
GMC Hood ornament (needs work) - SOLD , $20
Rear window trim - SOLD (missing a rightside pieces) , $20
Door glass - AVAILABLE , $50/set (both unbroken as far as I know, psgr side good)
Front License plate bracket - AVAILABLE , $10
Under The Hood
(does not appear to be the Delay model as the control stalk does not indicate)
A/C compressor - AVAILABLE , $40 (cut the condenser radiator off and it was still pressurized, should still be good)
Interior
Door sill plates - AVAILABLE , $10/set
Steering wheel and/or column - AVAILABLE , $50?
Radio, dash surround - SOLD , $15
Glove box - AVAILABLE , $20
Instrument fascia - AVAILABLE , $20
If available Id like the parking brake assembly, AC dash vents, jack and jack hardware, and rear view mirror if in good condition.
Discussion Starter · #36 ·
I'll take a look at the parking brake assembly and jack hardware but the vents are already gone and the rear view mirror is probably junk due to it being in a flood. that also means there is probably some surface rust on the p.b.assembly
Hi
25 Norman Drive
I give Tom (cyberray) a thumbs up. I purchased the woodgrain-look plastic dash insert from him. He told me in advance that it had a small crack in one corner, but that was OK with me because what I really wanted was the little "Caballero" script on it for my Caballero. He packaged it well, and it even arrived a day earlier than expected.
Motor vehicle Bumper Automotive exterior Vehicle registration plate Vehicle door
Body
Tailgate - PENDING
Under The Hood
Interior
Hello Mr.Cyberray,My friends call me Dezul and I am pushing 70 and this 1979 El Camino I have is keeping me going. I didn't see it in your list but if you happen to have the interior trim on the A pillar. I'm sure you know what I'm talkin about but I'm still going to explain the trim from the dash to the top of the windshield driver side. The splines in the windshield wiper blades are shot I don't have any wipers right now that Work . Wow, this is getting long now the lights in the dash for a speedometer everything stopped working so when I drive at night it's not real good.LOL
21 - 40 of 76 Posts
